Hello HP Tuners,
This is my first post. Im working on a prject of mine in which ive installed a Stock 2017 6.2 L86 with a OEM 2017 LT4 Supercharger.
Currently it has the ICT high rise adaptor for sc clearance.
I installed a 12644807 3 bar map sensor at the rear driver side of the blower.
I wired the entering air temp sensor into the 12644807 map sensor.
I have relocated the Water temp sensor in the side passenger side engine block.
I have wired the bypass valve into pinout 71 on x2.
I have added shorty headers on the engine.
I am running a 6l80E trans
All other components are all stock on the sc and l86.
I have tried running a 2017 z06, 2017 ss, zl1 Camaro, and a ctsv tune and my set up doesn't seem to like any. They all ran extremely rich to the point plugs are completely fouled. Ive made adjustments in the fuel tables. The l86 oem injector rate is 118 lbs. After making all types of adjustments here it still runs horrible.
Does anyone have a tune that would get me headed in the right direction for this type of set up?
