car goes into open loop and sets this code, has a tune on it P1SC STG 2 kit, LT's headers (ARH) new thermostat and sensor. Any ideas if the tune will cause this code???
The code is set by your coolant sensor signal fluctuating erratically. Since it's essentially a thermometer, it shouldn't do that. The signal reporting in should 'move' slowly.
You likely have a defective sensor or a faulty connection, etc....
Poll the sensor at the highest rate possible and see if that's the case. If you still have the old one, connect it and compare readings. Investigate and solve your issue!
thanks for the answer, but that was not exactly the question. the question is is there anything in the tune that will cause this to happen?
