Thread: 2016 roush s550 mu52 issues help
    I have a 2016 Roush Stage 2 S550. I recently tuned it and added MU52 Injectors as the Lu47s were at 108Dc on the stock Roush tune. Since adding the injectors i get a bad studder when going under a load at 1800 rpm when i hold it in 6th gear. First i thought maybe a tune issue. Spent hrs and hrs on it and still always did it. I Have tried using Ford racing Mu52 data and using the 13 GT500 data as well as the LU47 data in the Stock Roush Tune. I did Notice the Roush LU47 data is not the same as Ford Racings data on Website. I loaded everything back to Stock Roush and it still did it. I swapped the LU47s back in as well as the stock roush tune and the issue went away. I was not able to tune it on those injectors as they were already maxed out at 6500rpm. Has anybody ran into this? Log Attached
    Attached is the Stock Roush File with Gt500 Injector data.
    Stock Roush File with LU47 injector data
    Aug 2019
    26
    I have this issue. Did you ever get it fixed?
