Can we choose install path for RR ?
Is it possible to choose the install path for RR ? My new computer has windows on an SSD and everything else - except RR - is installed to a much larger HDD. I'd quite like to get RR onto the program drive as well but there doesn't seem to be anywhere to select the install path, or anything about in in this forum or the documentation ?
I've manually moved the RR3 install folder from the SSD to the HDD then used mklink to fool windows into thinking it's still on the c: drive, which seems to have worked, but a way to do it properly would be nice
Thanks.
Reason: bodged.
I too have an SSD and larger hard drive. The SSD is my C: drive and the hard drive is D: I install all my programs on the SSD so they run faster and I then move (relocate) my document, photo, music, video and download directories to the hard drive. You do this in the directories' property Location tab.
