I have a el camino ls swapped an LS3 with P01 VCM and im having issues with the fuel trims not working,i checked the tune every thing looks on point (on my side) or there's something that I have to change. Even in the scanner I force the PCM to go into closed loop there is no changes in STFT and LTFT. ill post the tune and scan of the car and please if someone can chime in and help.lean no fuel trims.hplTUNE4 dtc adj.hpt
