Results 1 to 10 of 10
Thread: 2018 Roush F150
    Mar 2010
    27
    2018 Roush F150
    I'm having an issue where the truck is limiting the throttle angle in first gear (like traction control but advance track is off). This seems to be limited to first gear only and I've maxed out everything that I can find that looks like it could cause it. Does anybody have any pointers on where to look?
    Sep 2010
    872
    Need a catalog to be able to see what it's doing, posting the tune will help as well
    Mar 2010
    27
    Sep 2010
    872
    Log using this channel config and this file, IDK if it will fix the issue since you weren't logging fuel source, but give it a shot and report back
    - Set your fueling to .76
    - Refined your VCT OP table a bit better
    - Refined your PE table a bit better
    - Turned off anti-Jerk
    - Raised modulation to max of 738(max allowed by table)
    - random other little shit mixed in there
    Mar 2010
    27
    That seemed to have fixed it. Thanks so much for your help.
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by Jn2 View Post
    Why .76 lambda vs .80 or a little leaner?
    Jul 2016
    613
    Interesting they are using the DI at 90% for most of the rpm range under full load
    Oct 2016
    Poland
    1,742
    Quote Originally Posted by LastPlace View Post
    Better safe than sorry. You can make it lean later after you have everything dialed in.
    Jul 2016
    613
    I get that but .78-.80 is plenty safe, thats why I'm asking.
    .76 is cat protection territory.
    Sep 2010
    872
    Bc he said he has issues with the tune and I wasn't sure if it would fix the problem with out him logging all the correct channels and trying the file I posted. I also didn't check to make sure all the other changes were good or not, didn't even look at his spark tables. So .76 is a decent middle ground considering the original file he posted was commanding .72 lambda. Now it's up to him to finish tuning his truck for more power
    Exactly...now that it works, the OP can spend more time dialing it in for more power
