04 ls1 gto. Turbo car. Under boost I easily max out the cylinder airmass axis of 1.20. I have a 2 bar custom OS. I need this so I can control spark differently from low boost to higher boost. Is there a way to do this? Someone said something about messing with injector data to scale? it. It sounded like I would need to retune my whole calibration for that? I really don?t want to do that if there?s another way. But I really need to be able to control my timing better. I leave in first gear on like 3psi which it definitely wants more than 12-13 degrees. Then I shift to second and give it say 7lbs. I may need to take away a degree or so and then third I may run 10.5lbs and need to pull it back to 12-13. Ideas? Thx
