Results 1 to 4 of 4
Thread: Dakota Digital Tachometer hookup
    Advanced Tuner 68Camaro's Avatar
    Mar 2011
    Van Buren, AR
    326
    Any of you guys know how to hookup and configure a Dakota Digital tachometer to the E92?
    I found the information that X2 pin 39
    is what to use for the tach signal
    but unsure of what ppr this provides and how to configure the tach (Dakota Digital)?
    I can't find anything in the programming (HPTuners) to turn on or change anything like on the older ECU's
    Hoping for some insight...
    Dakota Digital has a good tech support phone line. They should be able to answer you.
    Rick
    May 2018
    North carolina
    10
    The only way I could get my tach to work is use a lingenfelter can bus module, it works great.
    https://www.lingenfelter.com/product/L460260704.html
    5
    We used the Dakota Digital CAN/OBD II interface module (BIM-01-2) with a LT4 and E92 ECU. Connects to the OBD connector and uses CAN data for the tachometer as well as any other signal output to the CAN Bus by the controller.
