Results 1 to 3 of 3
Thread: p0606 stand alone e38
    Aug 2013
    australia
    364
    Hey guys I have a car im trying to tune but keep getting a p0606 code and limp mode, I think it's due to the throttle pedal. So its a camed ls3 in a f100 with 6l90e and a psi conversions wiring harness and throttle pedal assembly, the ecu is out of a vf 2014 maloo ute (Australia) e38.
    I think the pedal is not compatable with this ecu any thoughts?. I have posted a tune, but if any one has a stock file I can check over would be great to. cheers.
    Feb 2015
    Perth, Australia
    974
    would suspect this is likely an ECM OS mismatch or a power/earth fault. generally throttle issues will log P1516 or P2101 DTCs. P0606 defines as ECM processor fault
    Aug 2013
    australia
    364
    Yeah it?s weird I can get it to throw the code at 2500rpm and 43% throttle every time, definitely feels throttle related, I?m in the process off getting a stock file for it, because this tune has had the shit hacked out of it.
