Results 1 to 9 of 9
Thread: 2018 Mustang Gear Ratio Change
    Oct 2009
    321
    In a 2018 Mustang, in order to change the gear ratio, do you have to change the drop down to "Calibration" and then set the ratio to whatever it needs to be? I seem to remember having to do it that way on the '05-'09 cars.
    Thanks.
    Sep 2010
    872
    s550 cars you change it from the special functions the scanner when you are connected to the vehicle but not logging, it will prompt you for rev/mile of tires(shows current value so you can just retype the current one if it hasn't changed) and then gear ratio(shows current value so you can see what is programmed stock)
    Oct 2009
    321
    The only Special Functions that I have in the Scanner are Crank Relearn and KAM Reset. No gear ratio change.
    Jun 2011
    Cyprus to Worldwide
    65
    It make no sense to buy another device, HPTuner should do it!
    Sep 2010
    872
    put a ticket it in, they should be able to add it...
    Oct 2016
    Poland
    1,755
    Quote Originally Posted by skythunder83 View Post
    But ForScan is free?
    +1 for forscan FREE
    Jul 2017
    Baldwyn, MS
    31
    yes you change it to calibration. if its an auto car, youll probably need to change the NV ratio as well so itll shift right
