Results 1 to 3 of 3
Thread: 06 Procharged GT
    Jun 2016
    18
    06 Procharged GT
    Hi guys,
    First time dealing with the ford platform. I am currently trying to adjust the torque table since the car is equipped with a procharger. will be getting a 50 shot of nitrous on top of that. (39 lbs injectors seems to be small for the power output expected)
    I know I have to plot Indicated Engine torque against Load and then use the function to calculate the inverse torque.
    The problem I have is that when I want to log indicated engine torque and load, the scanner only have indicated engine torque REFERENCE and when I want to log Load, the only option available is Calculated load which seems to not go higher than 1.
    I have previously increased the load axis under the spark tables to 1.5 to give me some headroom. Or that is not needed ?
    Here is a log with calibration file.
    Thanks for your input.
    2250RPM_steady.hplFBNF255_tuned_rev1.hpt
    Jun 2016
    18
    I had the last row of the torque table dialed up pretty good. (torque error showing -40Nm approx) Then I decided to go and modified the driver demand table to see what would happen and now the indicated engine torque numbers went from 550 to 685 more or less...
    What is the proper way to do it ? leave driver demand alone and adjust indicated torque only ? Or ask for more driver demand first and then adjust the indicated torque table ?
    Seems like I am chasing my tail...
    Jun 2016
    18
    any input would be helpfull, torque table are almost stock but the car is running pretty good with no throttle closure or anything related to a torque error. I just wanted to have the right way to do it.
