Results 1 to 14 of 14
Thread: 2014 CTS-V going catless
    Feb 2018
    824
    I'm going to be installing b&b test pipes shortly. Main reason is i dropped down to a 2.35" pulley and don't want to run the risk of burning them up. Guys that have done this, are you able to run a few more degrees of timing at WOT than WITH cats? I'm currently at 16* at WOT in the upper rpms with a 2.55" on 91/93 octane (which seems pretty normal). I know i can always trial and error this, but i'd figured i'd ask first. thanks
    Aug 2009
    Calibrating
    3,372
    Less exhaust restriction can lead to more ignition timing
    Feb 2018
    824
    That's what I figured, just wanted to get some feedback from someone who has done it already
    16* on 93 seems low. On 93 and catless I'm at 20* on E85 it's 27*
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    With my C6Z06 twin turbo I also significantly leaned out my fuel curve especially during idle
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    I'm at 16.5 on 91 in AZ with cats.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Feb 2018
    824
    Quote Originally Posted by asteggall View Post
    occasional 91 octane goes in too. 16 is above 4000 rpms i believe ( i don't have my tune in front of me at the moment).
    Feb 2018
    824
    Quote Originally Posted by ttz06vette View Post
    i will take a look at this once i install them....thanks
    Quote Originally Posted by sgod1100 View Post
    Dealing with 91 sucks.
    Feb 2018
    824
    also, do any of you guys know which codes to disable in hptuners to prevent the CEL from popping up? I know i can disable any of the cat testing but i wasn't sure which codes to set to "NO ERROR REPORTED". Do i just disable anything that has to do with the "sensor 2" included in the description?
    You got it anything to do with sensor 2.
    Feb 2018
    824
    sounds good, thanks
    Feb 2018
    824
    Just revisting this..How much boost are you running with these numbers? Are you on a stock lower with a 2.35 upper like me? You have headers?
    Nov 2004
    St. Louis, MO
    474
    from Ctsvowners.com:
    ’09 Sedan Black on Black Recaros 6MT
    Forged HED LSA 10:1 GP 2.5 Ported LSA Heads/TVS1900 Johnson 2110s 2.70/9.55 Pulleys D3 Intake Lid Spacer SW 2”/Catless/Magnaflow Resonators/Corsa Spt DIY Flex Setup ID1300Xs DW300Cs + Walbro 297 Map Ref Aux
    Low Mount D3 HX and Pump -10 Setrab Oil Cooler Diff Cooler Lowered on JRIs Subframe Reinforcement Front and Rear D3 Sway Bars Core Shifter Mantic Twin Disc Clutch Swapped/Widened Sedan Wheels
