Results 1 to 5 of 5
Thread: Turbo LS3 Help
    Oct 2018
    1
    Turbo LS3 Help
    So I have a 2010 Camaro ss with the ls3 and six speed manual. I recently installed a single front mount 78/75 turbo with 4" intercooler, a set of 60lb injectors it retains the factory MAF sensor and I also installed a 3 Bar Map sensor. I was originally going to tune the car with the Maf and the Map but I haven't done any real tuning on the E38 and am lost if I can get a base map going I will be able to get it going I just don't know where to start should I do the 2 bar operating system or leave it running the Maf and MAP? I have a tune in it that runs the car idles pretty good and cruises ok but as soon as you start to get into boost it tries to go but doesn't. if any one can give me a hand in the right direction of where to go id certainly appreciate it
    Aug 2009
    Calibrating
    3,373
    You have a large g/sec flow limit.. is keep it MAF u less you have some odd tube routing
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Did you change the data for the injectors and the 3 bar MAP? Tune? Log?
    2013 Silverado 5.3, 6L80k 8.8
    Feb 2015
    Perth, Australia
    974
    I do all my turbo stuff in SD. I find it easier to apply a 2BAR SD custom OS and build a VE table
    Apr 2007
    1,104
    you can make well over a grand on the maf. Have a few Gen 4 vehicles doing this from 14 psi to 22 psi.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
