Results 1 to 7 of 7
Thread: 3.91 rear gear swab then gear not shifting ?
    Apr 2018
    32
    hi there
    i just swabbed my 300c stock diff to a 3.91 lsd complete set and an drive well but when i go first then second then third gear then the gear shift up to 2 and stand there nothing works , even manual shifting dont go and when i stop the car it shut down by it self from the gear lagging ,,
    i changed the ratio from the scanner and did reset of the gear readings ( didnt solve it )
    did change from the diablo ( also not working )
    any thing missed here ? should i do battery of and on or what ?
    note : abs light is on
    plz help >
    Apr 2018
    32
    any help ?
    Apr 2018
    32
    up up
    Jul 2018
    Trion GA
    6
    should bouGHT A CHEVY, MPH AND RPM ON A DODGE? i really dont know..
    Tuner coanan's Avatar
    Mar 2009
    S. Florida
    158
    What was the out come??
    2013 Chrysler 300S, 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force with 2.75 pulley, fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, Magnaflow Cat-back, FTI 2800 stall, Trans built by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. LG aluminum rad. Dual SRT fans. 4 piston Brembo upgrade. Mopar Stage one springs.
    Mar 2018
    Illinois
    326
    FYI there is a thread about changing gears specific to dodge here, although the software version is 3.0.
    https://forum.hptuners.com/showthrea...nt-3-0-Scanner
    Some more info on EGS52/EGS53 TCMs (2006 - 2014 Chrysler 300/300C)
    https://forum.hptuners.com/showthrea...e!-EGS52-EGS53
    Dec 2018
    5
    Did you make sure you cleared your DTCs with the scanner after updating with Diablo? The scanner would not update things correctly so I used Diablo T1000 to set the tire size and gear ration and cleared the DTCs with HPTuners Scanner and it worked.
