Results 1 to 8 of 8
Thread: 2014 LT1 to LT4 conversion .. TUNE INSIDE
    Jun 2018
    42
    I have a converted LT1 to LT4 blower set up on a 2014 C7 manual. This calibration, starts and idles. Can the VVE be extended from .880 to 1.24 ? or are most not going that high on their conversions?
    Jul 2015
    3
    If you hover over the pressure tab it will give you the option of going all the way to 3.0.
    Oct 2017
    Charlotte NC
    101
    I've extended my Pressure Ratio to 1.85 which I see with my LT4 conversion. So 1.24 sounds really low and should match what the engine produces.
    Aug 2009
    Calibrating
    3,373
    You can mod it to whatever you like...
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2018
    42
    I expanded the values and seems to be good.
    The only issue I am having right now is code for P0106 map sensor. I chose the SC-MAP-SCIAP-TIAP and getting error code. Do you have suggestions for correcting this or is this something hardcoded in the background for LT4 vs LT1?
    Oct 2017
    Charlotte NC
    101
    Normally for the LT1 to LT4 conversion the Map Sensor Config stays 'NA-TIAP'.
    I just got our L86 to LT4 blower swap running and I was wondering the exact same thing. It is running and driving right now. I am using the LT4 map sensor in the rear of the blower with the IAT wired into it. The front LT4 map sensor is not being used. We are running a 6l80E transmission. It idles and revs up great. It leans out very easy so I am taking baby steps with it.
    May 2020
    arlington tx
    28
    Quote Originally Posted by djyankees31 View Post
    does it matter if using the rear sensor the the sc came with for baro ?
    i have a break out wire and the evap exstender
