Results 1 to 8 of 8
Thread: Running single O2 sensor 2013 Mustang GT
    Mar 2010
    27
    I'm having an issue with setting up the car to run a single O2 sensor. As soon as the "number of sensors" is set to 1, the car will lose 75% of the dataloging channels. Are there only certain processor codes that will support doing this?
    Jul 2017
    529
    Why run only one O2 sensor?
    Mar 2010
    27
    Single turbo setup with one sensor in the downpipe.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    did you try repolling?
    I know after I turned on flex fuel strategy I had to repoll to see some of the flex fuel pids.
    Jul 2017
    529
    Just put both sensors in downpipe.
    Assuming you're talking the factory widebands?
    May 2016
    1,134
    I've done it but have to look at a tune to see for sure... Pretty sure I just do sensors 1 and turn off a heater and map LTFT Bank vs Cylinder or something like that to have all cylinders use the 0 sensor. If I remember correctly it's not happy if bank 2 sensor is the one you try to use.
    Mar 2010
    27
    Quote Originally Posted by ridenrunwv View Post
    This is what I tried and should have worked. I even went back to a stock tune with only one change (number of o2 sensors 1) to see what was killing the datalog channels. I ended up pulling the down pipe and fitting the second sensor to move past the issue.
    Jan 2014
    25
    Change number if 02 sensors to 1. This will use the passenger side sensor only. Then you need to map out what cylinder uses what sensor. This is to prevent bank to bank fighting if both sensors are in the same down pipe.
