Results 1 to 7 of 7
Thread: My tuner put a 5000 rpm limit
    Nov 2015
    Albuquerque NM
    31
    Hello I have a break in tune and now I need to just take it off .. Where would I need to look to remove that? Thanks for any help... Rick.
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    What car ?
    What year ?
    What engine ?
    Can you post the tune ???
    Nov 2015
    Albuquerque NM
    31
    2003 chevy Silverado 6.0
    Nov 2015
    Albuquerque NM
    31
    LQ9 with ls3 heads and stage3 cam
    Nov 2015
    Albuquerque NM
    31
    I hope it loaded
    13,576
    ECM 12050 and 12052. Either use the navigator function or find the cut off under engine > fuel > cutoff. You need to change both the RPM and ETC settings so something higher. Either go back to stock settings or pick a safe RPM that you are allowed to go with your given mods.
    Nov 2015
    Albuquerque NM
    31
    Thanks.. that did the trick..
