Results 1 to 9 of 9
Thread: need help on rev hang/increase between shifts 2015 mustang.
    Dec 2018
    5
    Hey guys new here, looking to see if anyone could help me figure out a little issue I'm having tuning this car. Run down on the car is a 2015 gt 2.9 front fed whipple with the 132mm tb, has return style fuel system, t56 magnum xl, id 1000s, long tubes, 4.10 gears. so we have this thing 99% dialed in but are having one drivability issue, when you clutch in shifting 2-3 or 3-4 the rpms will not only hang but if you continue to hold the clutch will rev until it reaches 3-3500 rpm then will fall back on its own. it is most noticeable when you initiate a shift in the 1,800-2,500 range anything above that it will not do it; also it is only in during 2-3 and 3-4 shifts in the 20-45 mph range as well it will not do it else ware. let me know were I possibly could look to fix this kinda lost currently.
    Jul 2017
    Baldwyn, MS
    31
    idle, torque, decel max rate drive: increase the values about 10-15 percent and see if that helps. i have to do that with the aluminum flywheel cars sometimes
    Dec 2018
    5
    10-4 ill give that a try.
    Jul 2017
    Baldwyn, MS
    31
    if it helps, dont be afraid to try 40 percent or so to help calm it down
    Dec 2018
    5
    no change in the issue.
    Jul 2017
    Baldwyn, MS
    31
    log your mapped point timing at the point of idle hang. it may be a torque table issue though
    Dec 2018
    5
    will do!
    Nov 2009
    All Around
    3,149
    whats your minimum throttle open rate, could be a cause and if it hangs your timing will decrease trying to pull it down
    Dec 2018
    5
    Got it figured out, since the car has a t56 magnum the gear ratios in he trans vary a large amount and causing the expected output shaft speed vs engine rpm table to be all screwed. Went into trans, shift general, gear ratio vs gears and changed all the ratios to match the magnum. then went into trans, manual and calculated all the min/max ratios for the t56 magnum gear set, flashed the car and problem fixed.
