Do any one see anything these tune keeping it from starting? PSI HARNESS DBW 242 COMPUTERjr bissette 1937 2004 dbw mod.hpt
learning
couple of things I would check for.
if this is for a ls swap vehicle, was the vats turned off in the tune
does each injector have power
is all the grounds connected properly
do you have good fuel pressure and is this new injectors or some that have been sitting a while and may be clogged
