Originally Posted by
TCSS07
yeah just checked the log and bank 1 is really rich and bank 2 is pretty lean so you should definitely check the car to make sure everything is hooked up correct - no vac leaks, intake leaks, pinched lines for vac and fuel or anything in that nature because each bank is off a significant amount from one another. also your car is commanding a 12.4 afr at idle and it goes into the low 10s driving - as stated above ensure pe isnt on could me a issue why you have a hard time starting the vehicle and also your idle throttle position is 30% which is high for idle
