Results 1 to 2 of 2
Thread: Running Lean.
    Oct 2018
    17
    Running Lean.
    Ive got an l59 with .500 lift Brian Tooley Racing cam and a trailblazer converter.
    Been on search to squeeze out more power and torque but seems ive been heading in wrong direction seems car is starting to run really lean.
    Any help and pointers will be greatly appreciated!RIde to work.hplCrown Vic Nicks 3rd Tune(TEST).hpt
    13,564
    Get a wideband o2 sensor, stop guessing with this stuff.
    The log says it's lean all over per the trims but without a wideband do you really know how bad it really is?
    Verify you have no vacuum leaks, no exhaust leaks pre o2 sensor, make sure fuel pressure is a solid 58psi all the time. Then start fixing the airflow model and stop going wide open throttle until you get everything squared away.
    Add more data to your logs, you need/want to be logging knock retard, your injector pulse width avg, commanded AFR or EQ ratio, cylinder airmass and anything else you think in required.
