Results 1 to 6 of 6
Thread: Returnless fuel system and boost
    Dec 2018
    21
    Hi guys, after roaming around the forum i cant seem to get an anwser. so if you could help i would really apreciate.
    Basicaly, i know that return less system have a fixed pressure fuel rail, so that ecu does change and adjust injector width instead, based on intake pressure.
    my question is, if i where to boost trought that kind of set up, with the factory 1 bar sensor and no flash option to have a 2bar sensor. What could i do to get proper fueling.
    as far as i can understand, lets say that maf rear a X amount of air at 2k rpm 15 psi of boost, then at 4 k rpm 0 psi of boost it would still read the same amount of air, BUT injector would need to be adjusted.
    So, boost referenced fuel pump ? or is there some kind of tweak around this to get a proper afr
    thanks again
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    returnless fuel systems have their limitations no matter what you throw at it. I ended up going return style/aftermarket hat and its working out much better.
    Dec 2018
    21
    thinking about it. couldnt i just put a 2 bar map and scale it to 50% ?
    HP Tuners Support
    (foff667)
    28,265
    dunno, my mustang doesn't use a map sensor, I guess it would depend on your application.
    Feb 2015
    Perth, Australia
    974
    what PCM and engine?
    Dec 2018
    21
    on a 2006 colorado,, anyway i ended up referencing the regulator intank. gotta get rid of as much as possible since it dont support pressure
