Having a strange issue with a 2015 Mustang GT that I'm tuning. I'm not getting any surging or anything like that, but after a moderate to full throttle pull I'm getting some type of throttle limiting. In the attached log at about 40sec in you'll see the issue. I made a partial full throttle pull in 4th gear, let the car decelerate a bit, and then tried to reapply throttle. If you look at the log you'll see that pedal is increasing while throttle angle either doesn't move or barely moves. When this happens the torque source stays on "tip in limit". If I let the car decelerate back to idle rpm in neutral the throttle will behave normally after that until I recreate the same scenario.
Specs on the car:
2015 Mustang GT M6
D1SC
ID 1000's
BBK Longtubes
Dynoed 647whp/528ftlb sae @ 10psi
Hoping someone can shed some light on this. I haven't been tuning Ford's for long, so I'm still getting the hang of these things. Tune file and log attached.
