Thread: 2016 chevy ss stabilitack light after cam and long tube install
    as the title states, I get a random stabilitrac light at idle and very low rpms after the cam and longtube install. I have the misfire test turned off. there is no check engine light. has anyone run into this?
    I have seen stabilitrak codes come up when the obd2 harness has been messed with or if it had factory trailer hitch package and the harness under the dash has been pulled. Not with just headers and cam unless someone unplugged a harness
    I believe I found the culprit. I had to tweak the misfire tables. even though it wasn't throwing a misfire code, it was still affecting the stabilitrak
    Jun 2017
    Bayville, NJ
    6
    2010 Camaro SS
    Quote Originally Posted by kbturbo View Post
    What did you have to tweak on the table? Mine does a similar scenario as you had. Only does it at idle so pretty sure it is related to this. Once you go above idle all is fine.
    Thanks..
