Today I tuned a 2016 Mustang GT w/ KB 2.8H. At around 6600 RPM, MAF Lb/Min in the scanner would flatline at 86.69 lbs/min. Is that a hardcoded limit? Everything looked fine so I proceeded to tune it no problem. Zero issues. MAF Period continued falling as normal. Fuel trims and wideband stayed in line. I know were at the limit for the MAF housing but is there anything I should worry about flat lining the MAF lb/min like that? Thanks.
