Results 1 to 7 of 7
Thread: MAF Airflow Limit 2016 Mustang GT
    Tuner Blown383's Avatar
    Sep 2011
    New Mexico
    157
    Today I tuned a 2016 Mustang GT w/ KB 2.8H. At around 6600 RPM, MAF Lb/Min in the scanner would flatline at 86.69 lbs/min. Is that a hardcoded limit? Everything looked fine so I proceeded to tune it no problem. Zero issues. MAF Period continued falling as normal. Fuel trims and wideband stayed in line. I know were at the limit for the MAF housing but is there anything I should worry about flat lining the MAF lb/min like that? Thanks.
    2007 Ford Mustang GT/CS: RGR 322 3v - JPC Intake - Vortech YSi-B - Magnum T56 XL - Built 8.8 - Full Suspension
    2008 Ford Shelby GT500: VMP Gen 2 - ATI 15% - SCJ TB - Full Bassani Exhaust - Full Suspension - Upper Pulley - Meth Injection - JLT 127mm
    Advanced Tuner Witt's Avatar
    Pittsburgh, PA
    380
    It's a limit on the sae pid. Applies to other makes as well.
    Sep 2010
    872
    SAE PID limit, but not the limit of the MAF, you can see that MAF period will keep dropping lower and fueling should stay accurate.
    Jan 2013
    Hawaii
    2,101
    PIDs that return 1 byte have a limit of 255
    PIDS that return 2 bytes have a limit of 65535
    These are the highest decimal value that can be represented with the limited bits.
    MAF is limited to 655.35 g/sec. Its formula gets divided by 100.
    They all have limits, RPM would flat line at 16,383.75 if you could get the engine to spin that fast. The formula divides it by 4, so you can see the 65535 value.
    SAE MAP channel would be limited to 255KPA or ~22-23 PSI of boost. Middle of your 3 bar MAP sensor range.
    255 Km/h or 158.45 MPH.
    Go to the wiki page to see the limits of others. https://en.wikipedia.org/wiki/OBD-II_PIDs
    Sep 2011
    New Mexico
    157
    Awesome. thanks a lot guys. I figured it was something like that. I knew in the back of my mind the newer ECUs, 05+ didn't have airflow limits that low but wanted to make sure.
    Sep 2010
    872
    Quote Originally Posted by Blown383 View Post
    it's a SAE PID limit, so 05+ would hit the same 86.69#/min limit that the coyote would, this is not the limit of the MAF, only the PID, the ECM still calculates airmass just fine past 86.69#, the PID just can't display it
    Feb 2017
    TX
    761
    If you'd rather it not flatline, you'd need to rescale and recalculate your inverse tables by increasing the last row's axis value in inverse. Theres also a limiter you may or may not hit when engine brake or etc torque request exceeds 730ft lbs.
