Originally Posted by
Hemituna
Any ideas? I've raised the values in the TB tables to decrease airflow and I've increased the Drivers Demand Tables.... still chasing it though.
Looks like it is fluctuating most of the time..even at smaller openings.
What you have done is ask it for more TB opening ( by raising driver demand), but then also told it that it is getting more airflow at same TB opening (by raising airflow tables).
So the 2 work against each other ... DD opens TB, airflow limit closes it, repeat, repeat.
Try leaving driver demand alone and go the other way with the airflow tables...ie decreasing them.(I know, smaller numbers huh...surely that can't work lol)
The airflow numbers feed into the calculated Actual (but really fictional) Torque...if you can keep this calc below the desired torque and stay below any airflow limits, then the TB will follow driver demand tables smoothly and precisely.
