Results 1 to 2 of 2
Thread: Can someone look at my log? I'm getting a misfire
    Dec 2018
    2
    Getting a misfire at higher throttle and cant figure out why. Someone please help.
    Apr 2011
    Chicago, IL
    763
    you need to add more pids to your channel list like injector pulse,misfires,injector duty cycle,knock retard,iat2,maf hz,afr commanded,o2's,etc....
    do you have a wideband to verify wot fueling?
    why is your tps only reading 60%?
    what fuel are you running?
    hows the ign system setup? look for faulty/arcing wires,faulty coils,cracked spark plugs,incorrect gaping causing spark blow out
    hows fuel pressure?
