Results 1 to 16 of 16
Thread: Hellcat , ZF8, How to get Target shift points
    Oct 2013
    Denham Springs, LA
    146
    Coming from GM, I've done a fair share of mopar stuff.. But the new ZF8's i haven't had alot of time to play with until lately.
    Bought my wife a 16' Hellcat, got some goodies to go on it, but i wanna just tune it first. I understand all the tuning side, but I'm having a hard time figuring out how to raise or lower shift point / shift rpm. Does anyone have a link or care to explain this?
    May 2016
    1,134
    Did you figure it out? Just have a lot if tables go change really. They over complicate it
    Oct 2018
    21
    The tables are based on output shaft speed so you need to multiple by the gear ratio.
    Sep 2008
    Portersville, Pa
    289
    Quote Originally Posted by ddtech View Post
    Derek, shoot me an email. I would be glad to assist you with this.
    Specializing in building and tuning 1000hp, daily driven, 9 second cars!
    www.ostdyno.com Shop Phone: 724-368-9000
    Feb 2019
    Lewisville Texas
    38
    I also sent you a email mike
    Aug 2019
    Quote Originally Posted by Flipfloptrader View Post
    what were looking to do is add 5% ( x 1.05 ) to an entire output shaft speed table for a given aggression number and trans setting, that will raise ALL the shifts 5%, or make changes to individual cells using the math ( OSS x GR ) Am I on the right track here?
    Mar 2018
    29
    Yes. You can make an easy Excel sheet to make a copy and paste table. Multiply OSS value by gear ratio to find commanded shift point. If you have a desired shift point in mind, simply divide by gear ratio to find OSS value to input.
    Note that trans will always shift past commanded shift value. Important to log trans to see how far your trans overshoots given gear on average, that way you know what to command.
    May 2018
    26
    hi friends does any one have the stock 2015 zf8 hellcat file ? i have some issues at ver low throttle first to second shift , is slip a lot and need to compere with stock file that dont have it
    Sep 2021
    35
    Quote Originally Posted by toxicperformance View Post
    Sep 2021
    35
    Do you have to change a multitude of tables or just that one table for the upshift? Also I noticed the 7000 rpm table had numbers that are higher than the 6000 rpm table. Can I make the 7000 rpm table exactly the same as the 6000 rpm shift which has the 1.05 multiplier in there? Thanks
    Quote Originally Posted by AlphaCat View Post
    The trans could be using any one of 12-15 different shift tables depending what Mode you choose and Aggression level.
    I like to leave "Normal" mode shift tables alone and just up the shift RPM on the "Sport" mode tables.
    Sep 2021
    35
    But do not copy the main tables values into the other tables. Multiply the other tables by the same percentage as the maximum rpm speed. Correct? ie 1.0475 I used on the main maximum engine speed. Then go to the shift tables and aggression tables and multiply by 1.0475?
    816
    Log shift ID
    Focus on one table
    The tables that are active with the paddles are the best ones to work with when starting out to figure out what you're doing because they won't change based on aggression.
    Log OSS, turbine speed and engine rpm. Notice that depending on what the converter clutch is doing there may a difference in the spread between OSS and Engine RPM.
    Great idea.
    Paddles and manual shift is usually 27 & 28.
    Disabling Aggression or rendering it neutral can help too.
    816
    Quote Originally Posted by duster360 View Post
    How do you do that?
    How do you do that?
    By changing the Aggression mapping (Upper = Lower)or (more tedious)making all the maps under each aggression the same.
