I am facing this problem that ECU pulls too much timing only at high RPM , I am sure it is not real knock. and I dont think adjusting knock sensor sensitivity will help because it is too much. what could be the problem ? some kind of torque management ? problem with SOI timing maybe ? VVE and maff are calibrated correctly. The problem only appeared after the cam swap.
thank you
