VCM scanner version 4.0.12 car is 2017 Chevy SS with LSA and 6l80. It is in third gear and that ratio is 2.36. I let it use the generic sensors.
What am I doing wrong with the trans slip math?
I am using ([4110.56]/[4221])-[4111.56] for trans slip math. That's: Trans input shaft rpm/Trans calculated gear ratio-Trans output shaft RPM.
If you look on the attached screen shot it is showing trans slip of 790 RPM. But when I do the math on a calculator I get: 8.066 RPM. 3711.1/2.359=1573.16-1565.1=8.066
