Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 66
Thread: EEC V and VCM Scanner
    Mar 2015
    25
    Good to know. Thanks for the update
    Feb 2019
    Hopefully it gets resolved soon!
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    vcm scanner logging with mpvi 1 works flawlwssly. Yet another reason i still keep an old cable around
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Jan 2019
    4
    Quote Originally Posted by moprblms View Post
    Don't hold your breath, they told me 6 months ago that the issue would be resolved soon
    Dec 2018
    Alabama
    6
    It's awesome progress for VCM scanner is coming a long, but has there been any progress on VCM editor? I know these things are waayyy outdated and there probably isn't too much demand for it. If there are no plans for support, or it isn't looking good, please let the few of us know so we can make other arrangements so we can tune these. Thanks for the good work guys!
  6. #26
    Dec 2013
    Slidell, La.
    1,015
    Yes, currently mustangs are tuneable back to 99, not sure on others, but eecv support is available, does require mpvi2 though, or nguage
    I HAVE TUNED A FEW OF THEM
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
  7. #27
    Dec 2018
    Alabama
    6
    Yea, I saw the support for most of the 2 valve Mustangs listed. I have an MPVI2 that I bought mostly for the scanner capability, but have done some tuning (still learning over here). The trouble is there is an outrageous amount of truck EEC-V vehicles in my area. I personally own two. I have several people waiting to have very minor tuning done to theirs, myself included. One would assume that since the Mustang PCM's have been figured out, the trucks shouldn't be that much different, but I can't say that for sure. I really hope they start support soon.
  8. #28
    Dec 2013
    Slidell, La.
    1,015
    They are close, ive had some convos about it, with different strategies, maurader etc. Its coming
    Michael Bray
    Slidell, Louisiana
    20yr Master Tech.
    Shop Owner
  9. #29
    Jul 2018
    6
    would like an update ? when can i tune my 2005 FORD EEC
    Quote Originally Posted by mlubis View Post
    Bad news for anyone with a Ford vehicle equipped with the EEC V computer. VCM Scanner won't support this PCM for data logging. Soon after recording the data stream will stop and the MPVI2 will disconnect. HP Tuners is aware of the problem but there's no ETA on when it will be rectified. Should've gotten SCT I guess
    Hi Michael,
    Thanks for sending this information in. I've consulted our engineers and they are aware of this issue and are currently working on resolving this. This issue only affects the EEC-V controller which happens to be the controller in your Mustang. I don't have an ETA currently as to when we will have this resolved but it is currently being worked on.
    Chad Stowell
    HP Tuners LLC
    www.hptuners.com
    just got credits for a 2005 fordthunderbird, hp cant tune EARLY FORDS , when can you guys catch up on the EEC-v anyupdate of when???
  10. #30
    heres an update. mine wont scan anything either. had it many months. still cant use it...would have been nice to have this information disclosed in the beginning. ive lost a hell of a lot of time screwing with this crap
  11. #31
    Quote Originally Posted by Eric@HPTuners View Post
    The fix is close. I tested today.
    so...we're comin up on a year from this statement....hows that fix comin? can i use it yet?
  12. #32
    Arizona
    263
    Maybe Covid 19 is delaying the fix?
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
  13. #33
    Quote Originally Posted by mach View Post
    So I've read on another post hpt seems to think it's an electrical issue. I dont think it is, I wanted to investigate just incase if there was a generic issue either from a circuit board causing interference on the scp bus or another issue causing noise on the bus lines and shy of using very expensive equipment I decided to disconnect everything. So far I've removed every fuse in the car that doesnt run the pcm or cluster and the only modules still connected is the pcm(obviously), cluster, ccrm and fuel pump module. All the grounds have been check and tested for resistance. I'll have to disable pats to disconnect cluster but that's my next approach. With all that done it's still glitching, I dont know how much further I'll investigate until I give up
  14. #34
    28,279
    Fix is in the newest MVPI2 firmware update 3.0.35 which can be found in the newest beta build.
  15. #35
    Waldorf MD
    774
    Just saw the email. Will try it soon...
    Daily Driver= 2003 BMW 330xi
  16. #36
    I tried it last week (inadvertently before it was announced) and it worked for me! Granted, I only tried a few minute-long log as I was just setting up coolant temp fan settings, but no crashes. Crossing fingers...
    If this works for others who have had problems, THANK YOU IN ADVANCE
  17. #37
    Oct 2018
    New Mexico
    10
    I have uploaded the newest beta. I tried to get my firmware updated but it still shows mine to be the 3.0.30 version. I tried resyncing my mpvi2, gathering info which shows I still have the older version. Not sure where else I can tried to get this to do a firmware update. I am trying to log a 03 cobra and the scanner has been giving me problems.
  18. #38
    Quote Originally Posted by arieso94z28 View Post
    same here trying to update to 3.0.35 and its only showing 3.0.30
    2003 Zinc yellow Svt Cobra
    Mods: x pipe/cat back, BBK CAI, 2.8 upper, 91 tune
  19. #39
    Connected to vehicle and tried to resync and still didnt update to 3.0.35. Beta version available for download is 4.7.704. Is that the most current beta verson?
  20. #40
    Sep 2020
    I'm new to HP tuners, have a brand new MPVI2 w/pro(just got it this week). I'm turning an 03 mustang. I have tried both the new release 4.8 and the Beta 4.9. Firmware was updated with the 4.8 release. Based on these comments, it sounds like the logging is better than it was before but still not great. Sometimes it will log without an issue and other times it will stop and totally drop the connection to the car. Sometimes it will log, then freeze, then log, then freeze, then log, rinse and repeat. This is with the USB cable. I tried the Bluetooth connection briefly, it didn't make a difference(probably worse). When I first started using it, it worked great, but now it is glitching more. Sometimes I need to resync the interface if it just won't connect to the car. Repolling pids after flashing an updated tune helps.
    I have an elm, x3, and qh. I might try data logging with those. Even with the glitchy data logging, I'm a lot happier with HPT than the other setup I was using.
