lsa drive by cable ecu and harness
gday i woundering if you can help me with my project putting a lsa motor into a 89 camaro .At the time of starting my project i got a th700r gearbox built and was going to put a dart 400 behind it and a lsa crate motor came along so i went that way instead.I needed to run a tv cable for the gearbox and there was no where on the drive by wire to run the tv cable so i bought a holley 95 mm throttle body and sent it to bowtie and they fitted a tv cable bracket to the holley throttle body part number 112-585.No ive been told i cant run a e 67 ecu with my set up but i saw a thread written on here years ago that i might be able to go this way .IF you could help steer me in the right direction i would app very much cheers john
