Having a problem setting up these injectors in the pcm.. the computer is limited to 64lb/h. How do I get those 1100cc on the fuel table when its limited to 64lb/h thanks in advance
base flow x flow multiplier = total flow.
so ~110 lbhr can be represented as a main flow of 64 lbhr and multiplier of 1.719
Thanks could you explain a bit more on that thanks
im not very good at explaining it for your model ecu. IMO you might get more help with this in the Gen 4 section which is the section for your ecu type.
Got it figured out thanks again Cobalt
Have fun tuning
