Results 1 to 6 of 6
Thread: Early E38 with 1200cc fic injectors
    Nov 2014
    48
    Having a problem setting up these injectors in the pcm.. the computer is limited to 64lb/h. How do I get those 1100cc on the fuel table when its limited to 64lb/h thanks in advance
    Dec 2008
    Nevada
    4,452
    base flow x flow multiplier = total flow.
    so ~110 lbhr can be represented as a main flow of 64 lbhr and multiplier of 1.719
    Nov 2014
    48
    Thanks could you explain a bit more on that thanks
    Dec 2008
    Nevada
    4,452
    im not very good at explaining it for your model ecu. IMO you might get more help with this in the Gen 4 section which is the section for your ecu type.
    Nov 2014
    48
    Got it figured out thanks again Cobalt
    Dec 2008
    Nevada
    4,452
    Have fun tuning
