Results 1 to 6 of 6
Thread: Early E38 with 1200cc fic injectors
    Nov 2014
    48
    Having a problem setting up these injectors in the pcm.. the computer is limited to 64lb/h. How do I get those 1100cc on the fuel table when its limited to 64lb/h thanks in advance
    13,569
    Double the stoich, half the injector flow rate, half the IVT terms.
    Now you have a 127lbs/hr limit. This is a pretty standard way to get around this issue. Tuning in lambda is required.
    Dec 2008
    Nevada
    4,452
    good to know
    Nov 2014
    48
    5FDP could you explain that a bit more! Thanks
    13,569
    Not much to explain.
    You have to in a way fool the computer so you can run really large injectors. If stoich is like factory you end up being limited by the small injector limit. In a crude way of saying it, if you double the stoich value the injector flow rate limit also doubles but need to half the flow rate because the table still stops you are 63.5lb/hr. So if you had 100lb/hr injectors that doesn't fit, so 14.68 now becomes 29.2 and the flow rate becomes 50lb/hr.
    I'm not going to type out the stuff for IVT terms so read this thread on that exact topic.
    https://forum.hptuners.com/showthrea...7569-IVT-Terms
    Nov 2014
    48
    👍 thanks
