Results 1 to 11 of 11
Thread: Whats wrong with my idle?
    Nov 2018
    Toledo, OH
    13
    When my truck starts up the idle is around 500 rpm and will not run without pressing the gas. After it worms up the idle is better but i still don't feel it follows the tune? I don't have my wideband hooked up yet so I'm not too sure on the fuel but it revs up fine so I'm not thinking that's it.
    Idle log.hpl
    Nicks Colorado 6.hpt
    2007 Chevy Colorado 2wd single cab
    2008 4.8L E38 PMC T42 TCM
    Elgin 1840P
    Pac 1218
    4L80E
    S475 Noisy Boi
    She slow 11.45 @ 129
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    On your log, the temp coolant temp never got high enough to go into closed loop. Any mods? If it runs ok warm, then work on your maf / ve curve in the colder temps. If you have a cam, the Base running airflow is low in the 200-1000 rpm areas. You have base rpm at 850 across the board and minimum at 850 also. Give the min a 50 rpm difference.
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2018
    Toledo, OH
    13
    The mods are in my sig, Elgin 1840P cam. Its running the custom OS speed density only.
    Elgin 1840P
    Pac 1218
    4L80E
    S475 Noisy Boi
    Apr 2011
    Chicago, IL
    763
    add at least 2 g/s of air to your braf from 200-1200 and see how that goes
    Jul 2012
    Florida
    1,459
    I forgot to memorize the specs on that cam
    Nov 2018
    Toledo, OH
    13
    I tried to work on the idle tonight, i increased the idle base running airflow final minimum all the way to 40g/s and the idle did not change much. i read thru the gen 4 idle tuning guide and increased the adaptive idle times and zeroed the tables out to stay out of them and the idle is still low. I ran the timing at 22 degrees. Any idea what im doing wrong?
    Nicks Colorado 10.hpt
    idle tuning min air 40g.hpl
    Elgin 1840P
    Pac 1218
    4L80E
    S475 Noisy Boi
    Nov 2018
    Toledo, OH
    13
    Cam specs if it matters
    Intake Valve Lift: .585"
    Exhaust Valve Lift: .585"
    Advertised Intake Duration: 283?
    Advertised Exhaust Duration: 286?
    Intake Duration @ .050": 228?
    Exhaust Duration @ .050": 230?
    Lobe Separation: 112?
    Intake Centerline: 108?
    Elgin 1840P
    Pac 1218
    4L80E
    S475 Noisy Boi
    13,564
    I'd probably go back to close to stock values on most of thing here.
    Back to stock timing, raise the idle spark advanced up to around 18-20 degrees. Lower the underspeed/overspeed spark correction tables. Add a little idle airflow and fix the airflow model so fueling is good before worrying too much about how it starts up. If you can get the fueling down for idle and normal driving you'd be surprised how much easier doing start up idle airflow and timing will be, because the fueling should be correct.
    Also make sure you have zero vacuum leaks and fuel pressure is correct at 58psi.
    Mar 2015
    233
    I'm on a Gen4 platform, so you have do this a little differently, but it helped me alot. I love Ed's tutorials. I try to learn anything he has to teach, because he usually charges for his class, and should.
    https://www.youtube.com/watch?v=XLW3RGSSD-g
    2011 Camaro SS
    Thompson Motorsports Dart 427
    ESS Tuning G4 Supercharger 1158whp/1017wtq
    DSX Tuning stuff
    Nov 2018
    Toledo, OH
    13
    As dumb as this sounds I cleaned the throttle blades which made a huge improvement! The intake and edges of the throttle blades were covered in oil from 200k miles in a express van, after cleaning them i went back to my stock timing and added 1 g/s to the base min airflow and it is much better. I need to work on the startup a little bit but other than that it is idling much better.
    Elgin 1840P
    Pac 1218
    4L80E
    S475 Noisy Boi
    Nov 2017
    Australia
    119
    Quote Originally Posted by justhereforinfo View Post
    ... I love Ed's tutorials. I try to learn anything he has to teach, because he usually charges for his class, and should.
    I've only just found Ed's training and tutorials in the last month...
    Unfortunately, Ed Mowton passed away last week. His son (who responded to my email) has been kind enough to keep access to the training material alive. I don't know what the plan is going forward, though.
    Ian B
    '15 Holden VF SSVR L77(gone), '19 Ford Ranger PX3 3.2TD, '22 Toyota GDJ150
