hello
i was set Power Enrich EQ ratio by 14.7/what i want.
but i found FUEL-GENERAL-Stoich AFR is not 14.7, it is 14.29.
so my question is when i set PE EQ ratio use 14.29/ insead of 14.7/?
hello
correct
thanks,
so stoichiometric AFR is 14.29, if i wanna 12.0 AFR should calculate 14.29/1.2=1.190(Power Enrich EQ Ratio)
is it correct?
