Results 1 to 6 of 6
Thread: VCM editor not showing me many parameters
    Potential Tuner LT1coupe's Avatar
    Nov 2018
    8
    I've followed along on several you tube videos & I do not have anywhere near the parameters displayed that I see others have. The tach output is one that I wanted to change from 4 to 3 to match my LS swapped S10 Tach, but it's not there? No PE delay, etc. etc
    I do have the latest down loads
    2001 S10 Xtended cab LQ9, Elgin 1839P cam, T56, Camaro brakes, 8.8 axle, 3.73 gears
    13,565
    Switch to advanced view then, under the edit tab.........
    Nov 2018
    8
    Thanks, didn't see that.
    Feb 2009
    Memphis, TN
    5
    I have the exact same problem. Advanced view is not showing me the proper parameters even after I closed out the file. Can anyone help?
    13,565
    Be aware that many computers don't have a lot of tables. So just because you see something on a V8 computer doesn't mean it will show up on a V6 computer or something similar.
    Feb 2009
    Memphis, TN
    5
    Everything is under the Parameter navigator now... It dont like that but I will figure it out...
