Results 1 to 7 of 7
Thread: Wide band MAF tuning feedback
    Dec 2018
    South Florida
    31
    **EDIT: New log posted below.
    Hey all,
    I just made my first attempt at calibrating my MAF with my AEM wide band. It seems way less complicated then using fuel trims.
    Anyway, I was hoping the experienced folks could give me some feedback on my log and tune that I was using to try this method out? I also noticed that the STFT's were still registering but not sure if they are being used in the calculations.
    Note - I did some prior calibration already using fuel trims and I wanted to see how far off from the WB they were.
    Thank you for any feedback or suggestions to improve!
    13,578
    In the scanner you would want to reset the fuel trims and disable the fuel trim learn I believe, then that would stop the LTFT and STFT from doing anything. Gathering data with any trims will throw off the wideband error.
    Set the LTFT learn to a high engine temp like 256 and your STFT O2 readiness to 1 MV to prevent the fuel trims from interfering with the wide band
    Dec 2018
    South Florida
    31
    I knew I forgot something. I need to remember to reset LTFT everytime. Ok, so if I disable the fuel trim learn in the scanner, does that mean I can ignore setting it in the editor?
    Quote Originally Posted by RySmDPT14 View Post
    I will do that and try again.
    Thanks for the input fellas!!
    Jul 2018
    Texas
    214
    Whatever you change in the editor has to be programmed/flashed to the ECM and/or TCM for the changes to operate. I'm making this statement based on your scanner vs. editor comment above. Once you log and modify your MAF, log again, and are happy with the results, you can then reflash those changes into your tune again and turn off the settings made to log your MAF in the first place.
    Dec 2018
    South Florida
    31
    Quote Originally Posted by DGS View Post
    Thanks for the feedback DGS. I do it that way already, just so I have the improved (hopefully) MAF calibration loaded and running while trying to improve on it again and so forth.
    What I didn't realize was that I had to disable CL in the scanner before logging, because even when I set the CL delay to the most time and set the O2 voltage to less than zero, it still has the STFT trying to make corrections.
    Dec 2018
    South Florida
    31
    Here's the log file for the first MAF calibration using my wideband.
    Can you guys tell me if I'm logging the correct PID's? Also, if my commanded AFR is 14.11, should my WB be reading close to that during operation?
    Thank you for your input!
