Results 1 to 4 of 4
Thread: Boost timing tuning method correct ?
    Hello,
    I?m logging g/cyl vs rpm and using that data compared with boost to determine timing at a given boost level.
    Ex. In my data log I see 2psi at .60g/cyl . I then go to the high octane fuel table and and adjust the row for desired timing at 2psi .
    Is this a decent method ? I?m sure it?s far from perfect but I?m trying to creep up on my base tune I made .
    Mar 2018
    South West
    115
    Yeah thats about right i usually copy the high octane the same as low octane
    13,565
    I wouldn't suggest that though, if the engine were to knock it wouldn't have a lower value of timing to revert too and it makes the knock learn factor pointless.
    Keep doing what you're doing to slowly dial in the timing curve to how you want it.
    Thanks for all the help!!!!!! I?m surprised I got this method right haha
