Results 1 to 11 of 11
Thread: Closed loop once we tune this generation
    I will post the tune later because I'm asking everyone I know as a tuner about this issue and I?m getting different answers
    These generation 5 cars are doing fine on dyno as stock but It goes on closed loop once we tune it. We always close the open loop by scanner to see the right lambda.
    What the reason of this high AFR after we write the car with a tune?
    Is only because of running on dyno?
    Regards
    Mar 2010
    Texas Hill Country
    3,299
    if you are referring to it being too rich or lean after flashing a new calibration, you need to let it run longer for the calculated temperatures to normalize because the flash resets many learned/calculated values. I typically wait about 2-3 minutes of driving (not idling) before I trust the output in the scanner.
    I?m referring to the too lean on dyno after reflash. It?s going like closed loop unless I close it by scanner.
    Aug 2009
    Calibrating
    3,376
    It goes CL after you tune it Bc you muck up the Tq model
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Do you mean it goes lean even on street?
    Please tell me no 😩
    Aug 2009
    Calibrating
    3,376
    Post tune and I’ll tell ya... but if it stays in CL on dyno, it’s going to stay in CL on the street
    14 Gen 5 Viper
    ats 2016 intake tune.hpt
    thx for your help
    please have a look at the tune and let me know if there is any idea needs to be changed
    regards
    your peak and brake torque tables are maxed out...you wont do this! thats your issue...btw i haven't even looked further in the tune
    Aug 2009
    Calibrating
    3,376
    That will do it every time.. max out the entire Tq management like the old days ha
    14 Gen 5 Viper
    Aug 2009
    Calibrating
    3,376
    Brake Tq tube can get away with... peak Tq is the main culrpit
    14 Gen 5 Viper
    Ok I put tq back as stock
    Things are fine and I?m just trying to know how to make the rev limit hitting fast back and forth rather than stock rev limit that just hold the RPM at red line.
    But we faced two codes
    P0090
    P00C8
    We?re trying everything to remove the ?power reduced? issue but no success even with stock file reflashed
    Any ideas?
