I had a perfectly good running truck with a bad 60e so I updated the trans to an 80e and did a segment swap. I rewired the trans wiring and added the front sensor. I did an entire write download. Now I have a severe miss and the tuner software says P01 ECM, GM Gen 3 V8, 4.3L V6. Operating system 12212156. I had updated the tuning software right before the segment swap. Could I have done something wrong? I had used this PCM in the the same exact truck running a 408/80e combination and didn't have issues before. Why does it say 4.3L V6? The truck has a 4.8L v8 from a 2006 with 2002 Camaro baseline tune loaded, has been running correctly for years.
