2007.5 Silverado, 5.3L
Sorry for what is probably a noob problem. I've done a bunch of searching, but the learning curve is pretty steep when you're first starting out.
This is my first tuning attempt. I bought my HP Tuner for an LS project I'm building, but then got involved in this truck yesterday.
Background: This truck was purchased at auction. It has been off the road since August. It's been to two dealerships and 2 independent repair shops. It goes into Reduced Power Mode whenever you drive it, but it sets no trouble codes, and never displays Reduced Power on the dash. The throttle just goes dead, with no other symptoms. In attempting to repair it, it has had 2 new PCMs, 2 new throttle bodies, 2 new gas pedals, 2 new Throttle Body Controllers, 1 new wiring harness and 3 new MAFs. (you should see the repair history on this truck!)
Nothing has changed the symptoms. I inherited it yesterday. I noticed that the problem goes away when you unplug the MAF. You can drive it anywhere, but the 1-2 shift is too harsh to drive it like that forever.
As a technician, I've seen that unplugging the MAF and putting a GM into SD Mode makes for high/hard shifts. It's quite normal and to be expected. I've also read here that the same thing happens when you change a vehicle to SD Mode with a tuner. If I apply both TCS patches the harsh shift goes away, but then Reduced Power Mode returns, so those patches aren't going to work for me.
Next I figured I would just slow down the 1-2 shift speed and reduce the 1-2 shift pressure. I've done this for all the shift tables I can find. It has absolutely no effect on the transmission. What am I missing?
I attached the tune. I've also recorded a road test with the harsh shift and attached it, if that helps.
Please take a look at the tune and tell me what I'm goofing up. Any help appreciated.
Joe
