Results 1 to 8 of 8
Thread: Advanced view only show basic parameters, please help
    Jul 2006
    9
    I have downloaded the latest version of the suite and originally set the view to advanced. If I read a new image or retrieve an old image I only see basic parameters and the OS screen is blank. The view parameter is set to Advanced. Any suggestions? I have searched and all I see is the basic/advanced setting. Thank you!!!
    Bob
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,262
    You can only choose between basic and advanced which you can switch under the Edit-view menu.
    Jul 2006
    9
    The edit menu always shows the advanced view checked but I only see basic parameters.
    HP Tuners Support
    (foff667)
    28,262
    likely just the tables for your specific application.
    Post your .hpt file or tell us about what application you are dealing with.
    Jul 2006
    9
    2000 Park Avenue Ultra - Stock Tune.hpt1997 Buick Riviera Stock Tune.hpt
    Attached are two tune files. I want to turn VATS off on the 2000 Park Avenue Tune. Looks like for the 3800SC the OS screen is supposed to be blank. Is there a way to turn off VATS? In the System tab it only lists PWM or Serial. I'm used to seeing an option for None.
    Thanks!
    Bob
    Jul 2006
    9
    I found a previous post on how to turn off VATS on 3800. Thank you for your quick responses!
    Bob
    HP Tuners Support
    (foff667)
    28,262
    Thats just the table set for those ECM's.
    13,564
    3800 computers are about as bare bones as they get.
