Gen4 To Gen3 injector help
So I converted the gen3 to gen4 injectors over using the spreadsheet online and I got everything swapped over, but I have some questions... for the ?Flow rate vs volts and the offset table? on the injectors I have installed(12613411 36lb flex injectors) the table is all zeros, this just doesn?t seem right to me, I pulled it off of two 5.3 flexfuel trucks and they were the same. Anyone have any input? The stock injectors I have have multiple ?higher value? numbers on the table. Idk. Maybe I?m over thinking it.
I have posted the spread sheet that i usesd to convert and a tune file for referenceLS1 to LS3 injectors.xlsTune 1.hpt
the injector need flow rate, deadtime(offset), pulse correction
i think the flow rate multiplier need to be 1,
the offset you can get it from stock gen 4 tunes, if you cant get the right offset you can use the old one you have and tune while you using the alternator and then disconnect the alternator and adjust the offset for voltage drop
