is there anyway can control thermostat open timing?
No.
Thermostat is a mechanical part. You choose what temp thermostat you want to run.
thanks.
i checked thermostat. it works by heat coil, heat coil push wax type.
so i guess ecm control heat coil timing..
Daily Driver= 2003 BMW 330xi
thanks..
so with out thermostat open early,, controls fan turn on low temp is not very help for cooling coolant......
stock thermostat. 105'c
top of thermostat has 2 electric wire.
What kind of vehicle is this?
2014 gm chevy cruze 1.6t
Go to Fans > Control by ECT > Desired ECT and lower the temp values. As per the service manual, the stat begins to open at 103C with 0 volts, and 80c with 12 volts.
So looks like the lowest temp settings would be 80C for the Desired ECT table. Then lower the fan temps to suit.
Russ Kemp
