Results 1 to 18 of 18
Thread: gm e83 ecm control thermostat open temp.?
    Sep 2017
    montreal
    58
    is there anyway can control thermostat open timing?
    13,571
    No.
    Thermostat is a mechanical part. You choose what temp thermostat you want to run.
    Sep 2017
    montreal
    58
    thanks.
    i checked thermostat. it works by heat coil, heat coil push wax type.
    so i guess ecm control heat coil timing..
    Waldorf MD
    774
    Quote Originally Posted by teamjin View Post
    thanks.
    No... the ECM controls fan turn-on temps (Electric fans only). There is no such heat coil timing. The thermostat opens with coolant temperature. If you have a 180 degree thermostat, the thermostat will open when the engine coolant temp reaches 180 degrees.
    Daily Driver= 2003 BMW 330xi
    Sep 2017
    montreal
    58
    thanks..
    so with out thermostat open early,, controls fan turn on low temp is not very help for cooling coolant......
    Waldorf MD
    774
    thanks..
    What temp thermostat do you currently have?
    Sep 2017
    montreal
    58
    stock thermostat. 105'c
    Sep 2017
    montreal
    58
    top of thermostat has 2 electric wire.
    Waldorf MD
    774
    No point in changing the fan temps now. I know 105c Is over 212F. Install a 82c or 71c thermostat and then set the fans 5c higher than the thermostat temp
    Waldorf MD
    774
    Quote Originally Posted by jaydubb71 View Post
    That's a temperature sensor...
    Waldorf MD
    774
    What kind of vehicle is this?
    Sep 2017
    montreal
    58
    2014 gm chevy cruze 1.6t
    Waldorf MD
    774
    Where is this car located?
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Go to Fans > Control by ECT > Desired ECT and lower the temp values. As per the service manual, the stat begins to open at 103C with 0 volts, and 80c with 12 volts.
    So looks like the lowest temp settings would be 80C for the Desired ECT table. Then lower the fan temps to suit.
    Russ Kemp
    Sep 2017
    montreal
    58
    Dec 2023
    Thank you for the image on the post ^^. Ecm controlled t-stat. 14 1.4t Cruze.
