Results 1 to 6 of 6
Thread: GEN III 6.0 DBW Throttle way to sensitive
    Oct 2018
    3
    Hello all,
    Can someone tell me if there is a place within HPT to adjust the throttle sensitivity? Its way to sensitive. I cant hold it at a steady RPM if my life depended on it. I have seen other posts where people are looking for more initial throttle response, I want less I believe.
    2003 6.0 P59 pedal TAC module computer are all from the same donor.
    Attached is my tune.
    Thanks in advance.
    im no expert but i think your enrichment rate(ramp in) is too high. set it to 1 and start from there
    Oct 2018
    3
    Thank you for the response. I will take a look at the enrichment rate.
    Aug 2016
    942
    Under Engine>Airflow>Electronic Throttle>Desired Throttle Area both tables are doubled or more up until 41%. I would return these two tables to stock.
    04 YD stock.hpt
    There is a 2004 Yukon Denali 6.0 stock tune to use for reference.
    Oct 2018
    3
    Thank you very much for the help! I will take a look at this as well!
    any luck?
