With 5.9 injectors only being rated to 160Mpa, and 6.7 injectors rated at 180Mpa, would it be worth it to run 6.7 injectors in a 5.9 so you can run more pressure? Im not exactly asking about flow through the injector, obviously I can throw nozzles on and get more flow. Im more asking if the added pressure would help atomize fuel through the nozzle?
